Maxxrickard
Maxxrickard's Avatar
04.21.2010, 07:14 AM
Yes i have seen your truck, its nice.
But i wonder if anybody tried à CD in à flm because i would like to know how big spur the chassa take..
SWEDISH FLM MAXX 5s MMM2200
George16
Supermaxx
George16's Avatar
04.21.2010, 07:37 AM
Thanks.
The largest spur a maxx-based chassis like gorillamaxx and FLM can take is 44T. The distance between the chassis braces/rails or opening of the FLM an gmaxx is about 46mm.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Maxxrickard
04.21.2010, 08:02 AM
I have 46t.. Just use mr. Dremel...?
sweetride4me
04.21.2010, 10:32 AM
that or get a kyosho plastic 44t spur or others that are out there ;)
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
04.21.2010, 11:21 AM
I believe the original users for that CD mount were FLM Maxx owners... See the links below:
Belligerentruth's Default Album There is a thread on this truck somewhere here, but I can't find it right now.
Hey Monster Mike: Maxx CD
RC Monster direct drive unit for FLM E-Maxx A quote from this thread: "Note that I had to dremel the chassis top plate so the diff spur would fit." Not sure what spur size he had in there.
As suggested above... maybe you could just go with a 44 tooth spur... If you stick with the 46 tooth, some work on the upper plate might be required.
Alien
Maxxrickard
04.21.2010, 01:25 PM
Kyosho 44t dont fit My diff, ofna spider..
Thanks for all help boys.
But à 46t cant be so much bigger than à 44t. Just dremel little...i fix
Maxxrickard
04.23.2010, 02:11 PM
ready...
Maxxrickard
diff:
ANGRY-ALIEN
04.23.2010, 03:45 PM
What a beast!!... the truck is looking good man... have you put it through it's passes yet?
04.23.2010, 03:46 PM
Sweet & sweet Mr Dremel is good at making things fit together when they dont normally...
Maxxrickard
04.23.2010, 04:24 PM
I havent tried yet. Still waiting for Mike to make same mount...
Popoxx
Sapere aude
Popoxx's Avatar
04.24.2010, 10:06 AM
Nice truck ! The body color is... original
I have a black anodized CD mount which is lying around, I don't know if I will use it right now
This beautiful MT musn't be a shelf queen, go out to test it !
Maxxrickard
06.14.2010, 03:11 PM
thanks Mike and RcMonster.
i am a happy owner to a CD mount
i have a few problems and need some smart help.
i must dremel in the chassi and a wounder if a should build up the chassi around me worked area.
diff:
chassi:
is it more space in a G4 chassi?
if anybody have a G4 chassi and would like to sell it or trade it to a FLM chassi let me know.
i need new center driveshafts. will any fit or how do i do?
it beautiful.
06.15.2010, 08:46 AM
Well, the G4 chassis has less room than the G2/ G3, since the stock tranny is narrower...
Since you wont need the tranny mounting points, theres no harm in cutting a slot either side ( seen a few guys do that actually ).
Custom drive shafts will be required really unless you get lucky- otherwise you can swap the output shafts/cups for the rc-monster shafts, then run the stock plastic drive shafts maybe.
Maxxrickard
06.15.2010, 11:49 AM
sorry i dont understand... Will My old centershaft fit the CD?shouldnt they be longer?
