reno911
Smelly Nitro meet your maker!
reno911's Avatar
05.02.2010, 01:24 PM
They should both work fine. I think what happened is someone just thought it would be cool to get these tires to fit on a relux low profile racing wheel one day and everyone took to the fad. The thing is it really doesn't matter what wheel you put these on the work great. Badlands are popular because they work, regardless of what wheel they are mounted to. The relux thing is a matter of visual aesthetics in my eyes. My first set of badlands I ran on maxamizer beadlocks and had zero issues in terms of the tire or wheel. My second set I decided to see what all the jazz was about and tried the relux. They worked just as well, and with mounting them on the inside it almost appears to be a narrower badland, like that of a lpr tire. Would they work any better than the badland on a correctly sized proline wheel, I doubt it. Will they appear slightly cooler, yes.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.02.2010, 01:53 PM
Well, when I get my new set, I will post my findings and photos....
Alien
Emaxx_Quebec
Emaxx_Quebec's Avatar
05.03.2010, 08:15 AM
another exemple of monting position and what I've try to prevent the foam from splitting.
Left one is mount on the inside lip Right side is mount normal (temporary)
Nard Cox
n00b
05.03.2010, 08:18 AM
Yeah, I believe I've seen those pics on the Traxxas forum as well :)
I like the inside look more.
ANGRY-ALIEN
05.03.2010, 10:20 AM
Yep ... that looks much nicer than the original mounting position.
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
05.03.2010, 03:23 PM
Cut badlands on LPRs....I did this set over 2 years ago IIRC
:D
Nard Cox
n00b
05.03.2010, 03:26 PM
Did you actually cut a piece of off the tire?
What about this washing method Arct1k mentioned concerning the foams? How does this work?
gtxracer
gtxracer's Avatar
05.03.2010, 03:36 PM
Yep, cut it off. No worrying about anything. Those tires ran goooood.
:D
Nard Cox
n00b
05.16.2010, 07:55 AM
Anyone can help me with this one?
Had the foams in water for over 24 hours but they didn't change :(. If the above doesn't work does any one have a recommendation about which inserts to buy?
Nard Cox
n00b
05.21.2010, 05:49 PM
Anyone any tips on the above?
Really want these tires up and running again. Buying new foams will cost me around $20 which is a bit steep seeing I only paid $40 for these tires, with foams on dish wheels. Who can give me a goldon tip / link?
bdebde
That's All Folks!
bdebde's Avatar
05.21.2010, 09:42 PM
Did you try the heat gun or hair dryer trick on the foams? If that won't do the trick, new foams is about the only option.
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.21.2010, 11:12 PM
You can run the Badlands on the Pro-Line LPR wheels (same size as Rulux Half-Ups) or the Pro-Line VTR wheels.
-Chad
PM ME IF YOU HAVE THE BELOW:
Nard Cox
n00b
05.22.2010, 04:24 AM
@ bdebde, I've put the hair dryer on the foams for like a minute but nothing happened. No idea how long I should point it at one spot?
@ Chad, yeah I know, but the rims arn't the problem, it's those damned foams :(. These were molded foams which are more expensive.
If I'm going to buy new ones, any suggestions??
PATF100 - PANTHER STANDARD MT FOAM INSERTS (4) WHITE
PATF145 - PANTHER TRUGGY FOAM INSERTS (4) WHITE
Or any suggetions from LiquidRC or eBay?
Chadworkz
Chadworkz's Avatar
05.22.2010, 02:17 PM
Ofna yellow molded foams (LPR if you use JC Rulux Half-Ups or Pro-Line LPRs or VTRs)! I have run them in various setups, including the standard MT size as well as the LPR size in both LPR wheel/tire combos and Rulux Half-Ups/Badlands MT combos.
-Chad
Nard Cox
n00b
05.25.2010, 11:13 AM
Chad, which one ? (100 / 104 or 106) ? Can't wait to try them on my RC8Te on this BMX park:
Will also order my Ofna 21067 there so I can get my STe back up and running.
[youtube]A7esAiWM8Sg[/youtube]
