mckrill
Technology Explorer
05.06.2010, 12:46 PM
And here is the bracket that will connect the diff-assembly with the top chassie plate and the side plates.
mckrill
Technology Explorer
05.06.2010, 12:48 PM
New parts - again... Starts to get expensive
Every single piece seem to come with a bill attached to it?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.06.2010, 12:49 PM
VERY Impressive, Your craftsmanship is impecable. All parts are well thought out and BEEFY.
You are the envy of the entire forum and everyone is watching anxiously to see more.
mckrill
Technology Explorer
05.06.2010, 12:52 PM
Started to fit the pieces together and cut of excess material
Side plates:
Lipo trays:
mckrill
Technology Explorer
Thanks Bondonutz!
nitrostarter
nitrostarter's Avatar
05.06.2010, 12:58 PM
Question, are you dead set on that gear ratio? Or how will you adjust gearing if you have to change pinion?
N. Rustler conversion
mckrill
Technology Explorer
05.06.2010, 01:04 PM
Shims - very simple and dead stable.
mckrill
Technology Explorer
05.06.2010, 01:09 PM
Here I started to drill holes for the assembly of the machine. I was considering to laminate the trays permanently to the sides, but the assembly/dis-assembly would be difficult, an I stall have not decided on the position..
nitrostarter
05.06.2010, 02:14 PM
Thats what I had in mind as well. Just seems to be time consuming...
mckrill
Technology Explorer
05.06.2010, 02:16 PM
Some more images with test assembly
(The gray dust in the corners of the trays are carbon fiber dust)
Extremely rigid setup
nuz69
nuz69's Avatar
05.06.2010, 02:19 PM
AWESOME build :D
Cant wait to see "THE flight of the tuned savage" :D :D :D
Don't break it at the first bash !
Your "JUMP" will be recorded on several cameras under different directions ?
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
mckrill
Technology Explorer
05.06.2010, 03:13 PM
It will break so I hope to catch the jump on video at the first shot...
Some more parts (and $)
Gotta have LST2 shocks, right?
Lipo, straps and new HV Hitech Servo:
mckrill
Technology Explorer
The small 2s Lipo is for the receiver and HV servo
mckrill
Technology Explorer
05.06.2010, 03:22 PM
Gotta have one of these HV servos is such a big truck:
Motor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed: 0.12
Torque oz./in.: 403
Torque kg./cm.: 29.0
mckrill
Technology Explorer
05.06.2010, 03:24 PM
The assembled Shocks compared to the old 1/5 shocks i used before
(and yes, they are ugly, but gold was so cheap @ amain)
