05.05.2010, 12:45 PM
Final truck update - M2C front and rear blocks.
I use M2C blocks on my buggy and they allow the suspension to move super free and make diff maintenance much easier.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
05.05.2010, 02:04 PM
I need to order the same. Unfortunetly, they are out of the front kit so waiting on that...
Seems like a solid setup.
05.07.2010, 09:33 AM
I wasnt sure if i should go 5s or 6s with a 1700kv motor. How do you find your power? Got any videos? Is 5s enough? Thinking about going 5000 5s or 5000 6s. both will be 40c.
05.07.2010, 09:59 AM
Hey Jeff, I'm running a 1550KV in my buggy on 5S, and it is plennnty but very smooth and controllable.
I would go with a 1350kv and 6s in a truggy or 1550 and 5S.
05.07.2010, 10:22 AM
Yeah, 5s on a 1700 is good. That's what I run and it's great. 6s would be too many RPMs on the 1700 in my opinion. If you have the choice though, I would suggest the 1350 on 6s, but maybe not the huge 5000 6s pack. The 5s 5000 equivalent in a 6s is going to be more like a 4000 or 4300.
05.07.2010, 11:31 AM
I run 3300mah G3 hyperions and they are more than OK. 5S is about right for 1700kv. very fast but controllable.
Radek
*EX-10 Eurus*
05.07.2010, 11:35 AM
Of course everything but the batts are on b.o. Grrrr!!!!!
So. This motor with the MMM and a 6s I will be set.
Thanks guys, sorry for the thread hijack.
05.07.2010, 11:36 AM
How long can you go on that batt?
05.07.2010, 11:38 AM
That's the motor Jeff, see ya at the DORC track...
05.07.2010, 11:50 AM
Thanks Mike. Now I hope everything will be instock in time
05.07.2010, 12:24 PM
about 13-14 minutes depending on track. we run 10minute mains so no need for heavier battery and VX G3 hyperions are able to push enough amps even from low capacity battery
Radek
*EX-10 Eurus*
05.08.2010, 06:11 AM
Does these fit the MBX6T?
So the M2C ones perform better than the stock MBX6T ones?
Site Owner
05.08.2010, 12:08 PM
05.08.2010, 02:46 PM
M2c toe blocks fit both buggy and truggy.
did some testing during today's race and Proline bulldog body gives bit more corner speed compared to jconcepts punisher
Radek
*EX-10 Eurus*
05.09.2010, 07:45 PM
Radek
*EX-10 Eurus*
