Didn't quite get to a full mockup on the weekend but i think this is a far as I need to take it. Note the balance point is just a touch forward of central. The distance between diff drive cups is about 40cm. I don't think the balance point will change much with the full build.
The battery i bought has helped with this a bit. I ordered a ZIPPY Flightmax 5800mAh 5S1P 30C 145x50x49mm, 776g. Fortunately for me the actual stats when it arrived were 145x49x44mm, 727g. You can see how much space i have for larger batteries but this battery pushed forward will help keep a good balance point. The battery can be mounted 'sideways' (as shown) to lower CoG. The battery tray is also mounted a bit high ..it could be lowered another 4mm or so. I went with an EC5 connector for the battery. Sure made soldering the 8 gauge battery wire easy. Anyone else use these?
ESC was going to be mounted above the servo but the servo has to come up a bit as the servo horn bolt will just touch the casing on full lock with how it's mounted now. So it will be in the position in the pic. There are two joint posts between the roll bar atm. I'll probably devise a custom bracket instead to mount the ESC to. The receiver will either just be double sided inside the TVPs or stuck in a small Team Associated box and mounted on the outside of the TVP.
The modified Tekno mounted fits well. There is about 1.5mm between where i ground the corner of off it and the slipperential diff cup but the mesh is too tight atm so it will likely be about 2mm. Thats with the 14t pinion which will be as small as i go.
Even though the mock chassis is MDF it's very stiff now that i have battery tray bolted in. It's mounted on stock motor deck mounts. I'm thinking i will add another two cross members to bolt the RPM Savage X skidplate to instead of the 'slot in' plastic crossmembers. So the final build should be plenty strong. Well at least i hope so, I have only be able to get hold of 5083 aluminium alloy. linc, what grade is the aluminium for your stretch build?
I used drinking straws to test the center driveshaft lengths. Looks like i will need about a 96mm and 161mm shafts. Haven't looked for those yet but if anyone has an idea lemme know. The slipperential diff cups are rather long so i might get away with shorter shafts if i pack them with o-rings.
Lastly, you might be wondering about the rod end attached to the shock tower. I've been trying to think of a way to support the shock tower as it bends a lot and eventually becomes permanently deformed. I'm thinking two tie rods one on the end of the shock bolt and the other bolted to a hole in the TVP. Not sure if this will be too stiff though, the tie rods will have some give but i am still considering it.
Lots more pics on
photobucket
