I really need to get this stuff out of here guys, I'm taking some very deep cuts on these but I have a family emergency that requires more money than I had in savings so these gotta go.
RCM RC8T with all the gas components and chassis too. Only been raced on an indoor track a couple times and I took it to the park to do some bark and grass runs - that's it. Haven't really been able to put a lot of time on the truck and it wasn't very used when I got it.
Quick rundown of what it's got:
Factory Team RC8T kit
two sets of tires - AKAs and ProLines
one practice body, two NEW bodies, ready to be painted
full RCM conversion with new chassis, side guards, battery tray, motor mount - everything
all the old gas stuff - chassis, tank, motor mounts - all that
couple extra parts like a front arm, misc nuts bolts etc
46T Kyosho plastic spur (very quiet, lower CoG)
big bore shocks
very very fast truck, tough too. I've never had a faster truck both technically and full on speed
If you want it paired with the Tekin setup and/or the M8 setup, I'll cut you a deal. Same goes with the crawler or charging system.
Tekin RX8 combo, RX8 needs one of the posts glued back on, so it needs to be sent in to Tekin but I just got it back from them and it worked fine until I accidentally ripped that off. Has a 1700kv T8 truggy motor with brand new sensor wire. In excellent shape, I just goofed. All they have to do is epoxy it back on. I can send this in if I don't get a good offer on it. Also comes with HOTWIRE (not separating those, package deal).
Hyperion 1210i charger, two LBA10 balancers, Neu converters (x2), 2s and 3s cables (x4), thunder power adapter (x1), LBA connectors, data cable, all boxes, too much to list. Will charge all the batteries listed plus more. Also have a modified PC power supply that works well that can go with it. Charge up to 12s at 10amps on this setup, it's an awesome charging system! Will charge anything and I mean ANYTHING. I'm letting this go for cheap, just ask me.
Airtronics M8 2.4Ghz setup, two of the Air small receivers (the $100 units), NiCd battery, charger, aluminum carrying case, everything is in good shape except the battery door which broke in half but doesn't effect charging, use, or anything at all other than it doesn't cover the door. I can package this with the RC8T or the crawler, no big deal. Rxs have no antennas. This is going for pretty cheap too, you're basically buying two receivers and getting a 2.4Ghz setup and M8 with case for free.
Team Losi Night Crawler turned into a very competitive and capable crawler. Has been lowered and the battery box was taken off. I have all stock parts still including the lights and all hardware. I also have the stock electronics. I'll be selling it ARTR, add Tx and Rx for now since it's already together. Has some lead in the stock beadlocks although I would take some of it out as it's a lot. Has white dot Rovers on there, those hook up like mad. Running a Mamba Max Pro that I bought new a short time ago with a Holmes Crawlmaster on 3s. Has two Hyperion 1200mah 3s packs that are ridiculously great on this rig. Also has a Hitec 5955 servo for plenty of turning power. Body has some battle wounds but no rips or tears. This thing crawled beautifully and I love driving it, it just goes up everything now.
Quick rundown:
Night Crawler with mods
two 3s Hyperion 1200mah lipos (5 runs each)
Mamba Max Pro
Holmes Crawlmaster 1000kv (goes up anything)
white Rovers
weights in beadlocks
only 1 month old, still have the box!
Hitec 5955 servo
stock tires, electronics, etc
SHOOT ME OFFERS!
