Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
06.17.2010, 06:17 AM
Originally Posted by killajb View Post
That is looking NICE!! The stance and front shock angle gives the appearance of an overgrown turbo optima mid or something. Those front and rear diffs sure do look small next to all that meat for the wheels tho. Have you shimmed the diffs? If so, hell shake it if you got it. Big legged mammas are back in style again!
Thanks - Diffs are shimmed and have Titanium Nitride gears installed:
We'll have to see if they hold up!
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.17.2010, 10:39 PM
I wish more companies made Ti-Ni coated gears and other parts. :(
-Chad
PM ME IF YOU HAVE THE BELOW:
bdebde
That's All Folks!
bdebde's Avatar
06.17.2010, 11:47 PM
It certainly won't be those gears that fail. I have them in my muggy; the only part that seems to go is the bearings on the rear diff pinion. When that happens, the gears can slide by each other. If that happens with the stock gears, the teeth will chip. I had it happen with the TiNi gears and they were fine. I also learned the importance of quality bearings in the diffs.
brian015
brian015's Avatar
06.18.2010, 07:24 AM
That's good to hear. I think I may have read about these TiN gears in your Muggy thread - thanks for the info.
I am also using Losi HD plastic diff cups inside the blue Al cases. I'm hoping that setup will be strong enough for this truck.
JAILBIRD
06.18.2010, 07:42 AM
Is the ratio of the Sportwerks gears the same as the Muggy or the LST? I need to rebuild the diffs on my 1717 powered beast already.
-JB
Semi Pro
Semi Pro's Avatar
06.18.2010, 07:54 AM
-JB
sportworks is the same as the muggy
losi sells the tiNi gears for the lst badged under their name
brian015
brian015's Avatar
06.18.2010, 07:57 AM
The Sportwerks Mayhem ST (truggy) gears are the same as the Muggy (11/45) - I know these work for certain and the TiN gears are often available on ebay.
I believe the Sportwerks Mayhem (buggy) gears are the same as the LST (13/43) - but I've never used these.
bdebde
That's All Folks!
bdebde's Avatar
06.18.2010, 08:49 AM
That is correct.
JAILBIRD
06.18.2010, 05:54 PM
I knew that, I am trying to figure out what my gearing options are. I want to get rid of the LST trans and go with a center diff. Now I just have to decide if I want to do a full conversion to a Muggy chassis or make a hybrid LST/Muggy type set-up.
-JB
bdebde
That's All Folks!
bdebde's Avatar
06.18.2010, 09:36 PM
I have a Muggy (going out to drive in a few minutes), and a LST2 with a center diff in the works. I figured the Muggy diffs in the LST2 would give me better gearing choices, and I have a bunch of the TiNi Muggy (Mayhem ST) gears in the parts box.
Chadworkz
Chadworkz's Avatar
06.19.2010, 02:48 AM
I know some people don't understand the reason or purpose of ceramic bearings, and would just rather buy new Avid bearings every month or so, but if you need a quality bearing, and don't want to have to replace it...ever, grab an Acer ceramic bearing, or even a Boca ceramic bearin...hell, even the Avid ceramic bearings may be good, but I have never tried them, just Acer & Boca.
-Chad
brian015
brian015's Avatar
06.24.2010, 04:59 PM
Front Driveshaft:
I made a long driveshaft for the front out of a Muggy center rear driveshaft that I cut in half (4mm diameter) and a piece of this:
8mm aluminum tube (2mm wall thickness)
I drilled and tapped three set screw holes in each end of the Al tube, ground flats on the Muggy half drive-shafts, and had to hammer them into the Al tube. Then I used red Loctite and 4mm set screws.
Length is about 10":
Red Loctite and assembly:
Installed in truck:
This is the part that I probably have the least confidence in on the entire build. I hope it holds up
bryan
bryan's Avatar
06.24.2010, 09:48 PM
Green loctite "sleeve locking" may also help unless you are just worried about twisting the alu. tube.
brian015
brian015's Avatar
06.24.2010, 09:55 PM
I'll keep that in mind if I need to make another one. I don't think the Al tube will twist - the walls are thick - but I'm not sure. I'm more concerned with the muggy drive shafts twisting out - so "sleeve locking" might be want I want. Thanks.
muggy
transtalon
muggy - 06.24.2010, 11:10 PM
You should weld the ends with a stainless steel hollow tubing. I had one with a brazed weld and it broke off. I had one tig welded and I never had problem with it. You can also mig weld it if you want. I don't think the aluminum tubing will hold up, i think it will twist or your setscrew won't hold up under big tires and lots of power. I could be wrong though. Goodluck.
