Maxxrickard
Maxxrickard's Avatar
07.12.2010, 03:49 PM
Nice. Now u have save some money for me.
SWEDISH FLM MAXX 5s MMM2200
Maxxrickard
07.15.2010, 03:59 PM
Can i use the same diffoil setup with the stockdiff as i used in My maxxtruck with 1:8 diff? 7k in the front and 3k rear?
07.15.2010, 07:25 PM
I dont believe so- there are fewer & smaller gears so you need to use thicker oil to have the same effect. Not sure whats recommended, but the traxxas website might have some info- racer setup sheets etc
Maxxrickard
07.16.2010, 01:37 AM
Hmm is it possible to open up the diff, its sealed..
If can do it, can i use a revo racesetup. Dont find any good for maxx truck.but im not that good to search and look..
07.17.2010, 03:26 PM
Yeah, they will open up easily enough- should be instructions & pictures on the traxxas website ( .pdf diagrams and manual ).
Maxxrickard
07.23.2010, 03:15 AM
No problem to open them up, but i really dont know what oil i should put i in. I have read alot and everybody say difference... 100k around? Just to save the diff. Its for the kids so its not that important its perfekt. But the stock oil is 30k and very soft..
Maxxrickard
07.25.2010, 08:10 AM
I Will try 30k rear and 50k in front.
Thats a setup many e-revobash trucks is useing..
Hope it Will be good
Maxxrickard
07.25.2010, 03:36 PM
I need servo suggestion..
I have found:
Hitec 7955
Savöx 1268
Savöx 1256
Any other nice servos? Witch is best?
What do you think of this:http://www.hobbycity.com/hobbyking/s.../_.17sec_/_52g
07.26.2010, 10:31 AM
If you want quality without question, then the hitec is great- I have a savox and although its really nice, it doesnt quite have the power I'd like- price is great though which works in its favour. You can look into Ace servos, BlueBird servos and Jr servos too- so many brands you could spend a month looking and never make a decision.
A pair of those Bluebird ones from hobbyking would be great though, plenty of power & still much cheaper than a single hitec..
Maxxrickard
07.26.2010, 11:48 AM
Hmm the blue bird is 14.2 kg, cant i use it as a single servo?
07.27.2010, 12:15 PM
Thats about 190in/ozs- not bad, but I think you'd find it a little lacking; I used to run a pair of hitec hs645mgs with a total of ~266in/oz and they struggled to move my wheels at a standstill, so...
I mean, look at the price though, ~$45 for 380in/oz of torque- thats a killer deal if you dont mind having a dual steering servo setup. If you prefer a single servo setup then something around 250 in/oz ( 18kg/cm ) is always suggested for best results..
Maxxrickard
07.28.2010, 05:53 PM
Thanks Neil,I will buy the hitec.
Can I use both of this to my MMM?what is the difference?
http://www.hobbyking.com/hobbyking/s...dProduct=11613
http://www.hobbyking.com/hobbyking/s...idProduct=9514
They looks the same to me...
07.29.2010, 12:36 PM
Hard case vs no hard case. The hard case is handy if the batteries are exposed at all, or you tend to have bad crashes that might send the lipo flying through the air if the battery straps fail- just a little extra protection, but it makes the lipo and little larger too.
With the FLM chassis, I doubt you would need the hard case verison, just use a couple good velcro staps ( along & across the lipo/ battery tray ).
Maxxrickard
07.29.2010, 02:06 PM
Extra protection is good and the hard case are cheaper.. I think I will go for the hardcase
Thanks Neil
Maxxrickard
08.02.2010, 03:19 PM
Does the savox have the same quality as hitec?
I find that savox have some new waterproof standard servo and they are strong.
Look at "Nyher från savöx" in the middle.
http://kullagergrossisten.se/
Will this fit my new emaxx?
http://www.liquidrc.com/index.php?ma...ducts_id=58906
