I love the update! I desperately needed the Max Power % adjustment for the racing I do. I've been using an odd throttle curve and just turning down the throttle EPA on my transmitter to get the correct power that I needed. We normally race brushed motors with a 4 cell battery setup (AAs to be exact
) and the track is specifically designed to race M18s and Micro RS4s with this power setup which gives us a full hour and a half of run time. I'm trying to bring the M18s that we race a bit more up to date with brushless and li-po but we need to maintain the same speed we had before. 40% throttle seems to match our older setup perfectly. I might find some use for the torque limiter too. If not on my M18 it will definitely help on my rc motorcycle!
I can't seem to figure out how to perform the motor test for my KV rating on my sidewinder speed control. I put it in test mode, update the ESC, run the motor with the red and green lights on but when I plug the castle link back in theres no information there. Can anyone tell me what I'm doing wrong?
There is one other problem that I've been having even before this update and the throttle limit has exaggerated it. It might have something to do with my transmitter (Futaba 3PM) so I'm going to try a different transmitter tonight after racing before I explain it.
Oh yeah and here is why I need to limit the throttle. Track is 35ft x 12ft and the surface is simply wall paint. Track width is 22in infield and 28in wide around the edges. We race anywhere between 5 to 9 cars at a time and most of us are very good drivers for super close racing that you just can't get with fast cars on a large track.
