with a full speed headon Curb hit with a
BIG CRACK sound !!
I toasted an aluminum bulkhead my front one!
sheared off the screws that hold it to the chassis and 2 that hold the front skidplate on !!
So i did not have a front Bulkhead so i used a Rear one.
with just some " slight " Tweaking i got it in and works PERFECT.
hell now the bodies fit better
i dont need to force them over the front body post's now
as you might be able to see in this pic i needed to tweak the Chassis just a little to get the angle just right.
as the rear bulk mount is flat .
and Overlook the Slightly bent back front shock
i need to replace them now to
and the front skidplate is still bent back as you can see in pic #2
and i completed my chassis and this is what it looks like now
But i remember that i was told the chassis brace i Modded for the steering mod would not hold up
well its holding just fine Even after this one!!!
and Yes i need to remove the 3.3 stickers...............
and the Paint on the rims is still holding up just fine sofar........
