18650's and their quirks -
01.19.2011, 05:20 PM
So for about the last year I have been playing with the 18650 styles of Li cells. Most are from used laptop battery packs. What I usually find is that they will be anywhere between 3S and 6S packs and up to about 4P. Most of the time I will have one set of the series cells that are completely dead. The others seem to charge and discharge fine within their parameters for the particular cell.
Recently I was setting up a set of cells that were from a 4S3P pack one set of parallel cells was dead, but the others seemed ok for my use. I had another 4S2P pack in the same situation (and same cells, brand and PN) so I took them apart to make a 3S5P battery. I ended up having a bad cell in one of the sets so I decided to remove them all mark them and cycle each cell individually.
I set up the test them by charging each one and setting it aside then when I was finally done (there are 15 of them) so they were able to rest for many hours until I started the discharge. I measured the voltage at rest then I discharged each one at 1 amp (1/2C for these cells). Some would only put out about 300 mah before they hit the 3V cutoff a few went into the 1400 mah range and some were less than 100 mah. The IR of each cell is between about 200 to 350 milliohms. The data is all over the board some of the ones with the highest IR performed the best at 1 amp and some with the lowest IR performed the worst and vise versa.
After playing with one cell started using lower and lower loads down to ¼ amp and I would get more than 1000 mah out of them. I will have to post the chart I made but it just doesn’t make a lot of sense to me. I am no battery expert so other than them being used cells I would like to know why they act this way.
Jeff
