Well I've been pondering what I want to do with this. I keep wanting to add truggy features to it, i.e. truggy diff cases (D8/D8T/etc), center diff, swapping to diff arms, etc. Not to mention the issues with fitting 8S between the rails. The above solution seems best, but I am just not content with it.
So I began to wonder why not just go with a truggy (my RC8T) to began with. The issue is I really want to run the Baja 5B tires/wheels. But there aren't any 24mm adapters; after poking around I found that Integy, yup the same, makes some extenders for "buggies" and a different couple of options; so I picked them up to see.
First is this.
http://www.integy.com/st_prod.html?p...155&p_catid=75
However, this don't work as when the wheels are added there aren't any threads left to thread the nut on.
Second is this.
http://www.integy.com/st_prod.html?p...31&p_catid=102
Well for my case, they were two wide so the pin wouldn't line up with the hole in the axle.
Third is this.
http://www.integy.com/st_prod.html?p...539&p_catid=93
Ah! They work; almost... had to grind a tad off the end to get the pin to match up, not too much and not where it will seriously hamper things. They are pretty well machined and very beefy, much more so than the standard RC8T axle extensions, but its probably made of the standard crummy alloy Integy uses. The one thing I really don't like is that all that keeps the pin in, and its a standard pin through design, is a large o-ring. I should note that these come with two sets of pin holes, the 3mm for like the RC8T and a slightly smaller set; the pin holes are perpendicular to each other. So these should fit the LST/LST2/LSTXXL, most 8th scale truggies and buggies, plus probably some more. Savage not so much.
These things are wide! From the outside of the bearing to the outside of the hex, the standard RC8T axle extension is 18.75mm. These are 38.5mm. So thats a 39.5mm, 19.75 per side, of extension! Not quite sure I needed that, could use probably just 20mm. Total width, outside hex to outside hex, is 422.25mm.
Here they are in comparison to the standard RC8T axle extensions...
And here they are on the truck... need to pull it apart and get a comparison shot between the two.
Obviously these are 23mm hexes, so need some metal tape to take up the slack for use with the 24mm Baja wheels. The biggest issue is that the threaded shank is only 9.5mm as compared to the 24mm Baja hex hub which has a threaded shank of 12.5mm. So the nut won't fully thread onto the shank. As a reference, the thickness of the wheel is 4.5mm for some ProLine Tech 5 wheels as compared to 6.5mm for the ProLine Desperado wheels. Basically there is about 3.4mm of thread outside the Desperado wheel and the hex nut is 6mm thick; slight issue. Suppose I could grind down the wheel about 2mm; wouldn't be prefect but still.
Now, if I could only find someone who could machine me a set of these, about 19mm shorter, and with 24mm hubs and 12.5mm threaded shank it'd be prefect.
For reference, the pin through design for the RC8T has a pin that is 3mm diameter and 16.5mm long; not quite the 4mm that the Baja uses, but its slightly thicker and definetly longer than the standard Savage pin.
And just some shots with the 5B tires mounted...
