This build is the coolest build around dude. You must have a lot of patience and skill to fit 12-14S in a 1/8 truck. People ask me which is more powerful, electric or nitro, and your truck is my answer. Keep it up!
If you're truck puts out 9000 watts of power, and it weighs about 7 kg, I worked it out to be putting out about 1700 HP per tonne. Haha! The Mclaren F1 puts out 599 hp/t.
The shitty weather came here again, so it'll be some more time before I can run it again, but I needed to strip it anyway and this time I'll put the water cooling in again
I guess the right was to put it is "pulled from the Lipos". It was the 2280 on 14s anyhow. I have some logs were the peak draw are over 10kW as well, but what actually turned out as power on the shaft is unknown. On the Typhoon the logger showed around 6kW.
That's awesome how the drive train stayed intact...
my 2280-5 Hi-Amp tore trannys, diffs and twisted custom 10mm CVDs..
Great Job, again..
Bmr4life: Yes, the motor mount is adjustable by adding shims under the brackets.
There has not been so many upgrades, but I have been working on the truck for some time now. A lot of parts has been replaced now and I have put the water cooling system back into the truck and made some new wiring etc.
I will get back with video and data when I have had the first test-run.
I found out that I had the parts to make a complete truck for the kids by using old parts...
This project is ongoing and I'm not sure if to start a new thread or just post pics here.?
The car will be a stretched SavageX (my own custom made CF chassie), central differential, The Typhoon 780 motor and a set-up allowing 6, 9 or 12s Lipo..
