rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
04.20.2011, 09:50 PM
Well here she is...now just need to do the electronics.
Bought my Wife a Rock Garden :027:
rckcrwlr
rckcrwlr's Avatar
05.03.2011, 12:24 PM
I added the Strapping Tape to the body to re-enforce the body and protect the paint at the points where it will rub.
Especially with these bodies...there is a lot of money in the body and paint...It's worth taking a little time to make it last for a while.
I use Scotch Strapping Tape.
It is a highly tacky tape with a mesh weaved into it. This helps in the durability of the body to minimize cracking.
First place I put it is at the body mount holes. This is where a lot of the abuse to the paint and body is done.
Then it is time to find all the areas where the body may touch the chassis, tires, etc. On a SC Truck, the Front & Rear fenders get a lot of abuse due to the tires tucking up in them. Make sure that you protect the edges and flat spots on them.
Finally, I figure that this thing will end up Turtle'ing, so I added some protection on the roof.
rckcrwlr
rckcrwlr's Avatar
11.07.2011, 02:39 PM
Look what showed up today... and it is going to be 70 degrees tomorrow. :thumb:
When you look close...what do you see??? Hmmmm, what does that mean?
rckcrwlr
rckcrwlr's Avatar
11.27.2011, 02:20 PM
So I got it installed...topped off them 8 Cells of Whoop Arse and plugged her in to take the test run.
Definitely running better. Did a couple laps around the neighborhood. Scared the sheat out of my neighbor cutting the grass.
After a fast run down the street, heard grinding.
Looks like the Pinion loosened up and ate the spur for Thanksgiving.
