the mother of cogging
revo madnesss
the mother of cogging - 04.24.2011, 01:25 PM
hey
i was wondering whether anyone could tell me what in the world is up with my mmm; its like it is cogging really badly.
it coggs for around 5 seconds regardless of how much i push the throttle, then it suddenly has a burst of power.
the wierd thing is when the motor is out of the car and has no load under it coggs just as much as my other mmm.
i know it not any other part of my setup as i used exactly the same electronics with my other mmm and its perfectly fine
thanks for you help
sikeston34m
sikeston34m's Avatar
04.24.2011, 01:50 PM
Send it in for repair.
Cogging is REALLY bad on everything. I'm surprised it hasn't let the smoke out yet.
When it's cogging like that, I'm sure it's putting a HUGE load on your battery packs.
I wouldn't allow it to cog like that for any length of time.
If you've checked everything, something must be wrong with the ESC.
04.24.2011, 02:19 PM
What firmware version are you running? Some people have had problems with 1.30. I think the latest "good" version is 1.24...
DrKnow65
DrKnow65's Avatar
04.24.2011, 04:06 PM
+1 try 1.24 software.
If it still cogs send it in for repair ASAP.
No point killing your lipo's with a dead ESC.
revo madnesss
04.24.2011, 07:49 PM
not sure what version software it is, will have to check tommorow
i didnt want it to come to this, me being in the uk means that getting a mmm replacement isnt easy, i sent a mmm out 2 months ago and still have heard nothing back
i really feel like giving up with castle
traxxasbasher13
04.24.2011, 10:05 PM
The last time one of my trucks did that it wasn't the esc it was the motor. If you have another motor try it with the esc before you send the esc in for repair.
revo madnesss
04.24.2011, 10:06 PM
thanks for the recommendation,
sadly i have done already and it still does it
traxxasbasher13
04.24.2011, 10:11 PM
Oh that sucks. Try going back to 1.23 firmware. Its the most stable firmware out of them all.
emaxxnitro
emaxxnitro's Avatar
04.25.2011, 12:21 PM
Check your solder joints on the motor bullets. a loose one will cause this to happen
808E
Pdelcast
Pdelcast's Avatar
04.25.2011, 01:09 PM
+1 -- and check the bullet connectors to make sure they aren't loose.
Patrick del Castillo
President, Principle Engineer
revo madnesss
04.25.2011, 04:15 PM
thanks for all your suggestions
today i went back to 1.24 and i did see a change; the cogging decreased to about half of what it was.
also i forgot to mention in the first post that the esc, motor wires and battery wires where all hot after around 20 seconds of testing
thanks for you help
04.25.2011, 04:24 PM
Yeah, hot wires means LOTS of current. After you check your bullets/solder connections, run it again (more gently than your vids to keep the ESC from blowing) and check for hot spots on the wiring. If any specific spot is hotter than the rest that's your problem.
Also, how are you geared? If geared really high, you're gonna have problems on takeoff and maybe adding in a little more start power will get it going easier.
revo madnesss
04.25.2011, 07:58 PM
the problem can only be esc related as my other mmm works completely fine when swapped with it
04.25.2011, 09:24 PM
Dont give up, they are normally one of the best r/c companies in terms of after sales support. If you havent already tried emailing ( including all the relevant details of your case, not just 'where's my esc?' ), you could try phoning or PM a castle rep here in order to chase up your case.
bdebde
That's All Folks!
bdebde's Avatar
04.25.2011, 09:48 PM
That MMM swap comes with a battery connector swap... check the connections (resolder them if unsure!)
