I would be so pissed if my MMXL kept failing like this...
I knew the MMM had probs, but i dont recall them being this serious!
Considering a caslte ESC takes 1 month to send back and for them to return a new one... you would never be running your truck!!!!
They are not, something is wrong here that is causing that. I am not saying that they never had or have any problems but to have this many failures in a row is saying something else.
Ok so you are running a 1520 motor on 22.2 volts (6s)? If that is the case you are running a good amount more RPM than the 2028-8s setup. maybe it is possible that with such a long run time that you are letting the batts get to low on voltage causing the amperage to climb which in turn is doing harm to the ESC? What do you have your voltage cutoff on the ESC at?
1520=1600kv X 22.2v= 35,520 RPM
2028=780kv X 29.6v= 23,088 RPM
Yes in both kits that got Mxl got also 1520 motor and on 6S with bec pro.
Thrid kit is got MMM, 1520 motor and on 6S. Working like a champ.
This black 5b kit is like cursed... just wont do more than 1 run.
Sorry but i got no saved data. I always clear the data base before new driving.
Will post data from my next drive but first rain needs to stop.
Jahay..if i ship to CC priority mail package comes faster.
If you ask for an advanced replacement Castle will take your credit card info and send you one before they receive your dead one... That makes it a fast turn around.
Do you think they would do that with an out of warrenty MMM? obviously there would be there usual charge... but i dont mind that... i may have to ask patrick if that is something they can do...
That's what I was thinking too, I have a 2s Life from when it was gas. So when you remove the red wire just leave the pin intact but insulated so you can still connect it to Castle link correct?
I actually use a very 4" extension and take the red wire out of that so I can just unplug the ESC side and plug it into the link. That way the ESC wires are all always intact.
I use Bec pro with castle quick connect.
This way esc wire is never unpluged from receiver as CQC is got separet wire that u plug to Castle link! Very easy to use.
Red wire from ESC u leave it, but u unplug red wire on the quick connect and viola.
