Originally Posted by RC-Monster Mike
I make them in batches, but it is quite easy to make a tray that I have made previously. Also, I would be happy to make a set of trays specific to the FLM chassis as well - all out of them at the moment, though. If you feel like getting some measurements, I can make the trays to the chassis for you. :)
Looks like FLM left plenty of room for packs
I would like my flat bottom trays to be 160mm x 52mm on the inside.
It looks like the Maximum outside side can be up to 175mm x 58mm and still be completely over the aluminum plate.
It's OK if my trays are a little wider on the outside then 58mm. I'm not too worried about impact on the trays, but I'm not sure if 3mm of side would be rigid enough.
I hope this helps.
Let me know what your thoughts are.
