does anyone know if rpm true track rear arms cam be used with maximizer beadlock rims on my maxx???
and i keep breaking these new drive shafts....from the brushless edition e-maxx.
they wont do 6s .
i need to put my old cdv's back on but they dont fit the new hubs due to the larger bearing aaaarrrrgggghhhhh
chris
inner bearings are 12x21mm, outer are 6x15mm ( can't remember stock sizes ). The only cvds that will work are ones designed for the new emaxx models- stuff designed for the old 3906 emaxx won't work as it used inner & outer bearings that were the same size ( new emaxx shafts use totally different size inner and outer bearings and a different style of stub-axle ).
ahhh i see...oh rubbish now i dont know what to do .
now i compare the old and new i see what you mean...the new has more length to it, the hubs are thicker on the new....the hole for the pin is further out...owwww that sucks.
that means making a complete new axle for my cvd's
im really thinking i should just go buy a new edition rolling chassis with no electrics....damn.
