mistercrash, the only graph about 300 you are thinking about is cell level capacity vs. kWh throughput... so after 300kWh have been cycled through the cell, it is at 80% capacity. That is ALOT of energy throughput.
Yeah that's what I thought, I didn't understand the graph correctly
Cell voltage: 3.447 (discharged a bit to get rid of top charge~99%)
Cell voltage under load: 3.089v. (after 30 secs of discharge
Discharge time: 1:57
Forgot to post the cell temp at start of discharge: 158F
Cell after discharge: ~170F
Cell voltage with the 16ft of booster cable (6awg.): 2.02volts
Cell voltage at end of discharge: 2.86volts
Cell temp end discharge: ~10 C (50 F)
Quite a difference in start temp and end temp, at sub zero temperatures the cell is dissipating much more energy as heat... as you can see in the voltage drop.
Well I'm at dsch # 200 and the cell reports up to 4360mah still and between 1-2mOhm according to 720i. If no one cares about this then let me know, otherwise I have no interest in cycling this thing.
A123 claims this thing can handle up to 10,000 cycles or ~280kwh energy throughput before it hits 80% of original capacity, I think that all we need to know, it's a tough little bastard, good for power cycling, but definitely not energy density, as it's only 70Wh/kg vs. 133Wh/kg for their 20Ah pouch cell.
This cell would be stellar as an engine starter battery.
