Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Manne
03.18.2015, 03:24 PM
Tried to use my huge Canyon tires whit the geode wheels but i kept killing the pins on the center driveshaft... They are just to heavy, but they really makes a good scale and hooks up great. And they have great gyro:
Used traxxas 17mm hexes for the Slash to mount them. Drilled to 8mm:
Found some new descent 23mm wheels! Thundertiger makes some!:
Bought some Panther paddles:
Didnīt really like how the Pantherīs hooked up in the rear so I bought some Proline 3.2 paddles and mounted on some old 40series 23mm Proline rims, had to cut them quite a bit:
Got some Rpm arms finally:
Manne
03.18.2015, 03:25 PM
And now some carnage!:
Worn shafts:
Bent the living crap out of a driveshaft:
Snaped the outputshaft inside and outside the gearbox:
Manne
03.18.2015, 03:26 PM
Bent the living crap out of the Flm draglink:
This is how i found the truck after a 150 Feet, (no there isnīt a zero to much) to flat . Seemed like the truck was flying for ever and ever and ever. In the gravelpit, they hade made a pile about 135 feet high with a perfect ramp at the top... I just couldnīt not do it. So on the last charge for the day I jumped it. Managed in some weird amazing way jump it four times before it ended up like that. Landed perfectly on all 4īs except that last time:
And thatīs about it for now! Happy bashing everyone!
ruudxd
03.18.2015, 04:48 PM
If I see this, I just have to bow for you, to get all the almost impossible thing done! ;) :)
Those wheels look great, and with a 23MM hex!
I only have some 40 series 23MM spare wheels now, I need some tires for these kind of beads:
http://www.modelsport.co.uk/pro-line...roducts/369184
Would the Thunder Tiger wheels with that kind of bead?
ruudxd
03.20.2015, 05:25 AM
What size and bead are those tires?
I am looking for some wheels for 3,8 Mashers, but they only come with a Traxxas bead...
Manne
03.23.2015, 10:45 AM
The Thundertiger wheels uses the same bead as the white 40series wheels above. The Thundertiger wheels are the exact same diameter as the traxxas geode wheels which the Masher 3.8īs is supposed to be mounted on but uses the "old school" bead. You should be able to mount the 3.8 mashers on the Thundertiger wheels mate.
Iīm planning to do exactly that for this summer season.
ruudxd
03.23.2015, 11:26 AM
Hmm, how do you want to mount the tires on a wheel with another bead?
Cut the outer ring off?
Or do you have 40 series tires mashers?
Manne
03.24.2015, 11:30 AM
I would choose to cut the two inner rings I think, so you hava a protective edge against sharp rocks, pebbles and stuff. Nope, 3.8 mashers is what Iīm planning to use. :)
ruudxd
03.26.2015, 05:46 AM
Hmm, I am curieus to see pictures of that!
If you see the Traxxas wheels, they don't have the outer ring, but the inner only, so I would cut the outer ring?
Otherwise the tire will be sitting trange on the outer bead?
Do you have a link or a part number for those wheels?
Thanks for the help!
Manne
04.06.2015, 06:58 AM
Thunder Tiger pd7532 :). Yes I understand what you mean but I would still cut the two inner rings and mount the tire inside the outer rings to keep it protected :).
Manne
10.20.2015, 04:05 PM
Hello everyone! Time for an update.
Have been bashing some, but still too little this summer.
Have made a few updates to the truck, New wheels and tires, and a new lid
And I finally manage to break my plastic servo mounts!, so i made some new ones from aluminium
The merv got jealous so i made a similar looking lid for that one too
And one last thing. The setup with the battery tray and everything sits the same as before, but I moved the tranny a bit more to the back so I could use stock lengt xl center dogbones and wonīt have to fab some up every time I break them.
Keep on bashing everyone!
Manne
10.20.2015, 04:56 PM
Oh, and here is the vid
[YOUTUBE]www.youtube.com/watch?v=mxi-jy62IuE[/YOUTUBE]
https://www.youtube.com/watch?v=mxi-jy62IuE
ruudxd
10.21.2015, 01:15 PM
Good to hear from you again!
Looks great!
How did the Masher plan work out?
Manne
10.22.2015, 05:49 AM
Thank you ruudxd!
I went with some old school v-thread, Traxxas maxx 3.2 tires on the Thunder tiger 23mm hex wheels instead, since they are molded thicker than the new school tires.
A friend has some 3.8 mashers layin around, might be looking in to what you are looking for if a chance is given It will fit :).
ruudxd
10.22.2015, 11:37 AM
That would be great, unfortunatly I am not in the financial position to buy the tires and wheels and hope they fit.
I personally like the look of the Mashers better then the tires you have on it now, but that is just me.
