First Run With The 9L
Qball76
First Run With The 9L - 03.27.2005, 04:40 PM
This thing is definitely what I've been looking for. I've got the strobe slipper on it with the 51 turn ofna spur and a 15 turn pinion and this thing still has torque for days. I can't wait for Jamie to get the 12-14 turn pinions in. Thanks Mike for answering my questions on Easter morning! What temps are you guys getting on this motor after a 14 cell run, my temp gauge is showing right around 145 degrees on the motor after several high speed runs, sound about right?
Sylvester
Sylvester's Avatar
03.27.2005, 04:43 PM
yup thats a good temp, good u got things working:)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.27.2005, 04:46 PM
I should have the mod 1 pinions in pretty soon as well. 145 degrees is fine for the motor.
Rcbros
Rcbros's Avatar
03.27.2005, 10:10 PM
LOL I so wish I knew about gearing. Thats one thing i've yet to experiment with since I started this hobby. Everyone keep saying if I get the right type of gearing with the 9L i could fry the motor or controller and that scares me lol.
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
liborlad
03.29.2005, 09:38 AM
Qball, glad to hear you're pleased with your 9L, I'm currently awaiting the 10L/9918 combo. I'm also going to be using the OFNA 51T mod 1 + 15T pinion setup, are you using the standard plastic spur, nylon or the steel one? I've ordered 3 plastic spurs but am a bit worried that the motor might tear them up.
Qball76
03.29.2005, 08:16 PM
I'm currently running the plastic spur, I've only got 5-6 runs on it but it seems to be holding up just fine. It's alot thicker than your standard spur gear.
RC-Monster Mike
Site Owner
03.29.2005, 08:31 PM
With the proper gear mesh, the plastic spurs hold up fine. Even 32 pitch is tough enough. I have run a plastic spur gear for over a year without stripping it.
lipomax
03.30.2005, 12:13 AM
I like plastic over steel spurs. When I used to have the hardened steel spur gear, I'd have to buy new pinion gears every 5th or 6th run!!!!!
liborlad
03.30.2005, 04:21 AM
I'll be sticking with the plastic! thanks.
