luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
04.15.2006, 04:02 AM
i think i willl go for a smaller tire, it eases out the stress for the drivetrain, the single speed tranny is out of stock at this time, can some one tell me any experience for the single speed tranny? yes mine is the extreme bl chassis, i'm gonna order a stiffer spring to take 4 shocks off, i already order the lvc that 's being recommended here, thanks for all the input guys:027:
coolhandcountry
coolhandcountry's Avatar
04.15.2006, 03:31 PM
The single speed is tough. I had a 2250 lehner on it with 26 cells. It would shear the pegs off on the slipper and not break.
luvsrc
luvsrc's Avatar
04.16.2006, 04:12 AM
great i will have that single speed for sure by the way here's some pics with a body on it:
ID:	1084   Click image for larger version
ID:	1085   Click image for larger version
Mike.L
Mike.L's Avatar
04.16.2006, 05:43 AM
nice truck luvsrc,
where did you get those rims can you post up the site from where you got them?
or just tell me the kind/name it is
THANKS!;p
  Send a message via MSN to Mike.L
Sylvester
Sylvester's Avatar
04.16.2006, 05:48 AM
I was gonna get that body, too! It looks really nice, are those aluminum rims?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
squeeforever
squeeforever's Avatar
04.16.2006, 10:30 AM
im pretty sure those are plastic, sylvester.
why not lower the body? it looks like you can lower it an inch or more.
maxxdude1234
maxxdude1234's Avatar
04.16.2006, 02:35 PM
There are probably clearance issues with the rear arms and the body. That chassis really needs an extended wheelbase body.
squeeforever
04.16.2006, 02:57 PM
oh, i see what your saying now. yea, that kinda sucks. i found that a mgt body fit my jt havoc nicely of course it was a tad wide but it covered the exhaust.
maxxdude1234
04.16.2006, 03:03 PM
I've got the same chassis as luvsrc, and I've currently got a LST crowd pleazer body on it. The wheelbase is fine, but the body is very long, high and wide (covers the chassis nicely though). I quite like the look of the new pleazer for the X1 CRT - on paper the specs look good; the wheelbase and width are the same as the LST pleazer, but its much less high and a good deal shorter. Probably gonna look at the CRT pleazer for my next body.
luvsrc
luvsrc's Avatar
04.16.2006, 03:05 PM
the wheels are plastic TRC made it i got it from my lhs, it's a pre painted body from traxxas i think it's called detonator?, i can lower the body some more, may try that next time
luvsrc
luvsrc's Avatar
05.05.2006, 06:13 AM
finally got time to do an actual speed test using my garmin gps, finally got the single speed tranny conversion into the truck and four shocks were out this time using just the stock tires (stock tires are 1 lb heavier than my other tires) total of 9 lbs weight overall with my other tires, but 10 lbs on the stock tire ones, top speed was 42 mph, it might go up a little more because the my testing ground is not really very open space with 15/72 gearing c50maxx on my 4s lipo with maximizer diff cup, no heat problems actually runs cool and can be easily get the gear ratio higher for higher top speed but i'm satisfied with the top speed
stampy
stampy's Avatar
05.05.2006, 05:01 PM
i pretty shur your gearing is off but im no expert. try 66 15
coolhandcountry
05.05.2006, 05:45 PM
It is not that big of a difference stampy. About like a 14 66 is a 15 72
