are they the same as say a normal 32 pitch 5mm bore? which is what i need for my rc10gt project because i have a wanderer 12s that's going in the truck and i was wondering if that would be the appropiate type of pinon
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
Mod 1 is a different size tooth. Its what nitro buggies and truggies use. Its roughly 25p. So, you'll need 32p with either a 5mm bore or 1/8th depending on what shaft your motor has.
