My brushless HPI Nitro MT Project -
05.22.2006, 04:49 PM
Well my first real brushless project has begun with me winning a used HPI MT roller with radio for $60. :eek: My only BL experience is with an RC10T2 with a Novak SS5800. I liked the power but needed more and needed it to be 4WD. I was thinking a 1/8 buggy, but figured a 1/10 would be cheaper and easier. I saw Camel's MT18SS and liked it, but didn't want to spend that much, so I picked up this MT.
I'm thinking a Feigao 380c 6L or 8S (8T here at RCM?) with a Warrior 9920 and 8 cells. My max is 8 cells due to my charger limit, and I'd rather not split it into 2 packs as this makes charging very long. Which is the better choice, the 6L or 8S? What size pinion should I look at? Any other recommendations for a controller? This will be strictly for bashing.
I'll update this as it progresses...wish me luck! :dft003:
The 8s won't necessarily have more torque, since it has to do with the number of amps the motors will pull. Unfortunately, Feigao doesn't publish the kt ratings (torque constants) for their motors, so we can't tell which motor will put out the most torque at the same number of amps.
It's relatively tough to decide without actual numbers which motor has the highest kt. The 380C 6L is longer, but the 540 8s is larger in diameter. They have similar kv ratings (by several hundred). If it were my decision, I would pick the 380C 6L. The can of this motor is a heatsink, so it can dissiapate heat well, and it has removable endbells that won't pop off like the 8s's endbells will. This also makes motor maintenance (bearing maintenance) easier. Besides those things, the 380C 6L is less expensive.
kt in oz/inch/amp is 1352/kv. Kt is always proportional to kv. So a higher kv motor will always have less kt. The total torque depends on the number of amps times the kt. In theory, a 540s will have slightly more torque than a 380c 6l. They both will draw about the same amount of amps, but the 8s having ~4400 kv verses the 6l having 4900 kv will have slightly more kt. Once you gear the 8s higher to compensate, both motors should theoretically have the same power output, although the 6l spools up faster in real life.
You may get a lot of flex from that motor mount, which will affect the gear mesh. The mount may need more than two screws holding it to the chassis. Check out this thread to see my motor mount. It's overkill really, but there sure isn't any flex.
Yeah I saw your MT2 thread. I know the mount isn't great, it's temporary until it causes a problem. I liked cold fusion's but I didn't like people sending money and not having a mount months later. I don't know anyone with a machine shop and e-machine wants $60-$80 and a month to make one so I'm kindof stuck at the moment.
I was actually thinking about that or maybe something going to the spur gear housing. I don't do 20 ft backflips like a lot of people here that I've seen so it may just be ok, but I'll probably end up with a brace of some sort.
