Castle Creations Phoenix 110HV controller
captain harlock
RC-Monster Captain
captain harlock's Avatar
Castle Creations Phoenix 110HV controller - 08.10.2006, 08:21 PM
Who recommends me to take this controller if he knows that it costs only $230 and it can handle up to 110amps, 12s lipos, pistol grip compatible, double heatsink, but no proportional break? it has an option of 'hard break', though.
Nice to meet you!
squeeforever
squeeforever's Avatar
08.10.2006, 08:38 PM
Thats gonna be like full brakes....I wouldn't unless you use mechanical breaks. It will possibly damage the motor from a heavy truck slaming to a hault all the time.
Procharged5.0
Procharged5.0's Avatar
08.10.2006, 08:45 PM
I second Squee's opinion. It would be fine if you adapt a mechanical brake from the T-Maxx and program the brake to the disabled mode.
You do have a T-maxx don't you?
08.10.2006, 11:56 PM
You know, I saw that ESC a while back and remember being quite impressed with its construction. IMO, that is how an ESC is supposed to be built (from an electronics standpoint)! I like the aluminum layer in between each layer of PCBs/FETs and the ample heatsink. I bet that thing doesn't overheat or blow FETs! Too bad it's not apparently meant for vehicle use, unless you use mechanicial brakes.
captain harlock
RC-Monster Captain
08.11.2006, 12:10 AM
Shutt down the ESC's break and use mechanical one..?!!
Sorry, my GrandArk Phase.1 is the first monster truck I've ever owned.
I guess I need to use an additional servo, right?
Nice to meet you!
Serum
Serum's Avatar
08.11.2006, 02:45 AM
Yes it does use an extra servo.
Starscream used one in his truck. (for testing purposes)
captain harlock
RC-Monster Captain
08.11.2006, 10:50 AM
Hmmm. It would only make things more and more complicated.
In the future I might use 8s lipos, and that is why I need a high voltage controller. Probably Schulze is the only way I can go, but MGM has a good controller, too. Though I'm not sure how good it will perform.
Nice to meet you!
Serum
Serum's Avatar
08.11.2006, 11:54 AM
mgm is the way to go, unless you feel like investing money in an expensive non insured bbq..
I use the MGM too, it works perfect.
andywpj
08.11.2006, 03:05 PM
Hello.
about this Castle Creations Phoenix controller i saw somewhere forum talk about "World's Fastest RC Car Challenge" show, some guys used NTC3 with HV85A esc and 8s Lipo run at 134.4MPH a record.
but i think maybe can do that , because HV can support to 50V high volt.
Serum
Serum's Avatar
08.11.2006, 07:42 PM
Nice for speedruns, but it doesn't say anything about his further behaviour.
Starscream used it in his truck too
starscream
RC-Monster TQ
starscream's Avatar
08.12.2006, 05:39 AM
Hey Serum,
I did use the HV110 on my truck but it had some undesirable and random issues because of its incompatibility with pistal grip transmitters. The controller handled 8s with a 12xl wanderer quite well. The wanderer got pretty hot but the esc was relatively cool. I was able to get the HV to work with my JR XS3 but not with my Nomadio Sensor. I must say that the 12xl on 8S was a bit too much even for me and I'm a power hungry fool :027:
I have since purchased the Quark Monster Pro 125B from Mike and am pleased with it so far.
Ha Ha
Serum
Serum's Avatar
08.12.2006, 05:43 AM
I guess you need to setup the 0 line, right? because it's meant to start from negative with the plane RC?
So once programmed right (or using a stick transmitter) it works okay?
braking with it is not an option, right Starscream?
starscream
RC-Monster TQ
starscream's Avatar
08.12.2006, 03:42 PM
Serum,
The controller does have braking options however, because of the way around the 0 line issue it won't shouldn't work. I never use esc brakes as I run manual brakes on all my trucks.
By default, the nuetral position of the throttle is half throttle. In order to get around that, I configured the esc full brakes to the nuetral position of the trigger. I then configured the esc for forward only and was able to control the tuck normally. This worked with my XS3 but not my Sensor.
The only problem with this was that every now and then, when I used the manual brakes, the esc would reset and the nuetral position would revert back to half throttle which actual is more like full throttle. Its not cool to have you truck take off WOT out of control :019:
I was able to stop the truck because of the manual brakes but still... not cool.
I have since given up with the HV because it is currently not reliable.
Ha Ha
coolhandcountry
coolhandcountry's Avatar
08.12.2006, 06:09 PM
What happens if you used the mixing option?
Hook the thrid channel up to brakes.
Hook the second up to the esc. Set the reverse to 0% epa.
The adjust the 3 Channel to operate the brake when you go to reverse.
Gustav uses this method. So it is his idea.
Peace!
Country
Help support the
Rc-Monster
Buy here
captain harlock
RC-Monster Captain
08.13.2006, 12:37 AM
I believe we should wait for the MAMBA MONSTER MAX to see what it will deliver. I doubt its gonna be beyond 200-220 if not less. The Mamba Max is already a fantastic controller as far as I've heared. The MMM wont be any different.
I guess MGM is my ultimate choice, for now.
Nice to meet you!
