yeah it says reveresd up top but when i put normal it still reacts with reverse and when i put reverse well then it work just fine....I need to figure out how to switch but i don't have my manual with me for this radio
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
Try this....set your radio to factory setup....and then program the controller again, and make sure the motor is programmed for the forwad direction, if the motor still goes backward when you move the throttle forward, just reverse the motor direction, by either switching the 2 outer wires , but im not sure how for the quark
