couple of questions
BADBOY2
couple of questions - 09.17.2006, 05:41 PM
about lipos ,when u say BALANCED what do u mean by that?how do u actually balance the batts?i also saw in the mag that peak racing platinum doesnt need balancing..what lipo batts and charger can u recommend?ill be using it on my savage with quark125b..
and is a feigao 9L motor enough or will work with this esc?
thanks. i dont kno if i have to hijacked a thread or just make a new one so i made 1..
Gustav
Gustav's Avatar
09.17.2006, 05:54 PM
Balanced means that each cell in a pack is of matching voltage.An imbalance can damage the cells.You need a pack that has taps for each cell that are wired to a balance connecter that you plug the balancer into.most work by monitoring the voltage of each cell and discharging cells individually untill they match.There's no standard for balance connectors so you may need an adapter lead to use certain packs with certain balancers.
BADBOY2
09.17.2006, 05:57 PM
do the lipo chargers have that balancing features?or u have to do it manually?
squeeforever
squeeforever's Avatar
09.17.2006, 06:19 PM
You have to buy a seperate balancer.
cemetery gates
09.17.2006, 07:49 PM
also, you might want to think of a bigger motor like a xl, maybe a 8xl? how many cells are you going to run?
BADBOY2
09.17.2006, 08:26 PM
im thinkin that 6cells wont be able to do it with the savage so i was thinkin of running 12cells or a 2 packs of 2s2p lipos is that good?
cemetery gates
09.17.2006, 08:32 PM
that would be fine, you might want to look at a 7xl or a 8xl for that cell count.
