One last look at my shopping cart -
12.15.2006, 03:40 PM
Well the 7xl are out of stock currently so Im going with an 8xl for the 9920 and power them with 5s.
Does the Li-Saver work with both 5 and 6s?
I have a reciever pack but do I need it for the 9920? It has "3Amp.BEC on/off Function". I dont know what that means. Will that alone provide 6.0v for my servo?
What gearing for a single speed tranny should I start with? Is 16 or 18/66 32p a good start?
The Li-Saver is supposed to auto sense between 2-12 cells. Most everyone on this forum recommends the use of BEC or receiver pack to help keep the ESC cool. As for gearing I again recommend using Brian G.'s calculator (the same link as the wiring diagram in my previous post) to start and see what speeds you are after. Hope that helps.
I diddnt understand the "gear calc" but I tinkerd with the "motor selector" and "Random Parameter Solver". Found that an 8xl with 5s and 18/54 gearing is "good" for a for a top speed of +/- 40mph, 20/54 for 45mph and 22/54 for 50mph without any overheating warnings.
Is it OK to use the Li-Saver with a car that is using reverse?
I ran into a problem with another brand of Li-Po cutoff device. Most are made for airplanes so when they do their "pulsing" they pulse down to near 0% throttle. 0% throttle on a car controller is full brake or full reverse if reverse is engaged. After coming to a complete stop it then went to full speed reverse. I really should have known better, but I guess the excitement of a new toy got to me.
Seeing a 8 pound buggy flying backwards down your driveway and into the iceplant at near 40MPH is quite alarming :026:
Perhaps the Li-Saver doesn't pulse below mid throttle (neutral for cars)?
Just thought I would bring this up.
Matt
the one that Mike sells will work good for you.
Matt
They have more than one version of the li saver.
It has a plane and car mode.
Mike sells the car mode one.
No worries on wide open reverse.
Rc-Monster Buy here
That is good to know. Since I switched to the Mamba Max, I don't need a LVC any more (I run 4S).
I just wanted to make sure the same thing didn't happen to rustnpede in case the Li-saver did the same thing. He might not have as much iceplant as me :005:
. . .I just wanted to make sure the same thing didn't happen to rustnpede in case the Li-saver did the same thing. He might not have as much iceplant as me :005: . . .
Thanks for looking out. No ice plant here just rocks, not so r/c friendly. Unless its a crawler:025:
