GorillaMaxx360
GorillaMaxx360's Avatar
12.19.2006, 06:03 PM
I am not sure of this term but i know they are rubber sealed and they keep the dirt out and they are better than stock on performance. read a review here
Tazz
Custom
12.20.2006, 08:17 AM
Originally Posted by hyperasus
Those Dura Trax bearings are what I've been using and they blow out easily.
I have been running them for almost a year and had zero problems with them. Granted, I do not do any big jumps but for normal use (dirt and normal jumps) they have worked for me.
neweuser
neweuser's Avatar
12.20.2006, 12:37 PM
All maintenance!
Two reason why they are. 1) lack of maintaining them, or 2) not right for the application, such as speed or what not.
hyperasus
hyperasus's Avatar
12.20.2006, 02:29 PM
Maintenance for my bearings? What exactly am I suppose to do, pull the bearings and give them a kiss for good luck? Besides, I doubt it’s the case because I've had them blow out pretty quick. The ceramic bearings I got form my LHS already have more use on them then I ever put on those duratrax bearings and they are still working perfect. I was just hoping to find some good ceramic bearings that were affordable since they seem to work so well.
neweuser
neweuser's Avatar
12.20.2006, 02:32 PM
:010: :010: :010: :010: :010:
Actually, I good cleaning to get the dirt etc out. I think anyone can tell you that is needed and is always a good idea.....
crazyjr
crazyjr's Avatar
12.20.2006, 09:28 PM
For glue, I use Pacer Zap CA super thin, haven't blown a bead since i started using it
mt_enthusiast
mt_enthusiast's Avatar
12.22.2006, 12:59 AM
I've been away for better than a year, BUT Mike had recommended the Team Losi tire glue to me "way back when." Also, I know Boca Bearings is an option, but not the cheapest. HTH, Mike
Hey Larry ;)
  Send a message via Yahoo to mt_enthusiast
BigSushi
12.30.2006, 10:55 PM
Best tire glue IMHO is Racers Edge Fusion Tire Glue. Hands down the best stuff I have ever used! Only down side is - The remaining glue does not last long after you open it. It actually fuses the Tire and Wheel together.
http://www.racers-edge.com/store/cus...6&cat=0&page=1
