basicly heres wut happened. I altered my lisaver so that the the wires woudl only connect to one batt, instead of both of them together. The guy who i bought the lisaver form said thats why it went in reverse instead of stopping the car. When i pluged in one of the packs, a puff of smoke came out of the esc. I instantly remove it and looked at teh controller. I took some pics of it. Seems liek the brown wiere was loose, u can see it popping from teh side. That is what i beleive coudl have been it. Or it coudl have been cuz i put the lisaver to one of teh batts. Heres a diagram
Heres the pic, Is it savable? Could i just resolder the wire back on and have it running again? Please tell my my esc isnt fried! This is bullsh**! Outta my 4 brushless escs i ever had, 2 of them broke! WTF! :035: Its my freaking 2nd broken 9920!
It's really hard to say. Usually, when there is a puff of smoke and lifted traces like in your pic, it usually takes out something else and it's difficult to determine what unless you know how to troubleshoot electronics.
That sucks man, IMO take advantage of the holiday specials. I see one solution to your bad luck ; TAKE YOUR TIME! Every time i see you post your either in a rush or you just want it to work. If you take some time and do things right first ; you will have a happy smile on your face. Im not saying this caused you 9920 to go up in smokes but ive seen a bit of things you've rushed. For instance ; You cardboard battery holders in your revo ; that was humerous, i have to say :) ;)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
I WOULD HAVE BEEN BETTER OF JUST DRIVING MY TRUCK INTO THE OCEAN.
then only the electronics would be shot
I was ripping sand runs at the beach today when I SLAMMED into a unseen small concrete small devistating sorta hidden concrete block about 40 yards away. SEVERE IMPACT. 20 to 30 MPH EST
DAMAGE
New Era ext CHASSIS bent mid length
TRAXXAS SHIFT SERVO DESTROYED
EXPENSIVE STEERING SERVO DESTROYED
2 5S APACHEE PACKS / PUNCTURED
GORILLA STRAPS BOTH TORN
SCREWS SHIERED ONE GREAT ASSEMBLY FRONT BULK
QUARK 125B DOES NOT TURN ON
FIEGO 9XL BOTH ENDS CAME OFF BUT I think it will still work
Doesn't look to bad to me. Just lose contacts. If your good (and I mean good!) at soldering, try removing the wires and seeing how bad the damage is, then solder them back on indiviually and seperate.
The reason for reverse was it was a plane lisaver.
The reason for the smoke was you hooked the lisaver up wrong.
I hope this helps.
I think you may want to invest in esc while sale is on.
Peace!
Country
Help support the
Rc-Monster Buy here
Hey, you could clean up the area...and being extra carefull...you could resolder the black wire on...and change the wiring back to the way it was on the lipo saver and give a shot again....it wouldn't hurt to try
Well, thats the way they sell the lisavers on RCM, with the little deans extention. Thats how i set mine up. Before i had one RED wire on one pack, adn the black wire on the other.
so with the little deans ext on it...it worked fine.....but when you wired a red wire to red wire and like wise with the black....it fried....hmmm
i cut the connector of mine as well & wired it in that way to......now im a little worried
I just tested mine with it wired ....without the deans connector....ans the red wire goint to the + battery wire off of controler and the black giong to the -on the controller as well...and it all worked just fine...no problems at all.....so are you sure you didn't wire it on wrong or something?
That shouldnt have been the problem, since i doubt the deans connector would lose some kind of interference, and Shayne's (sjcrss) works. I bet you put the wrong polarities together.
Losi 8ight e
and that was with my 7 cell NIMH packs to.....so i think a polarity might have gotten switched or something and it backfed the juice to your controller
