Originally Posted by BrianG
The only bad thing about the lipodaptor is that it stops the charge as soon as it sees the 3.6v/cell peak, which would be the very end of the CC phase of charging. You'll lose whatever the CV stage would put into the battery. It's not much by comparison, but if you're using 1p A123s with fairly low 2.3Ah runtime, it could make a difference...
Personally, I'd do the manual CC mode thing MetalMan suggested. It just involves you to watch it carefully and make quick adjustments quite often. Also, this assumes your charger will let you adjust the charging current on the fly...
The CV phase on these LiFePO4 cells is rather short. At the end of the charge (3.50-3.60v) the slope of the voltage increases (thanks to the ICE I can see this). If you didn't stop them at 3.6v, you'd notice that the slope of the voltage continues to become greater.
Originally Posted by Scoob
Got it. So the CV mode doesn't kick in untill 4.1v. It would be a lot of trouble to keep the V constant on two packs at once. I was going to run them in series for a M-truck. I'll just have to stick to lipo. Thanks.
What sort of voltage are you wanting to run? I'm charging 5s (16.5v) A123 on my ICE right now (18v fully charged).
Originally Posted by t-maxxracer32
so if i just bought a lipo dapter my ice would charge them automatically liek it does with a normal batt? how long would the charge time be?
Yep, the LipoDapter doesn't do anything until a certain voltage is reached.
Charge time depends on number of cells used and the current you charge at.
