coolhandcountry
coolhandcountry's Avatar
02.06.2007, 11:12 PM
What are you running jolly? I am going to go for something not really slow but run like 15 to 20 top speed. I have locked my diffs already. It has some big joes on it as well. Moved the suspension and shocks to have great travel. I haven't tried it yet. Maybe tomorrow.
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.07.2007, 05:09 AM
all stock twin force. except for center uni's.
mamba max esc.
stock motors.
2s orion lipo 3200mah.
thats the most important.
thing to come:
hb pro diffs, 4.3/1.
17mm wheels and better tires.
better motors or only one motor if he is powerfull enuff.:D
some sweet wiring so i can run 2s2p.
maybe a integy sbec 5 amp if its any good<= any input on this?:032:
losi 8ight-t
xray xt8
jollyjumper
RC-Monster jumper
02.09.2007, 11:14 AM
help!
i dont know what i should do.
i like bashing alot.
but also trial and stuff.
want center diff for bashing.
but then it couldnt trial any more.
what to do:032:
losi 8ight-t
xray xt8
coolhandcountry
02.09.2007, 08:11 PM
Build another truck. That is the easiest. It is real hard to have one truck to do all.
You build a truck for every thing you want to do and you have it covered. :)
jollyjumper
RC-Monster jumper
02.10.2007, 05:10 AM
i'll bash with with this one, then see bout the rest.
losi 8ight-t
xray xt8
jollyjumper
RC-Monster jumper
02.11.2007, 05:27 AM
mamba max says on the side:
2~3S lipo
6~12 cells NI-MH
does this mean i could run 12 NI-MH's without seperate BEC?
thank you.
losi 8ight-t
xray xt8
02.11.2007, 12:23 PM
You might be able to. It also depends on the servo load. If you are running one lower power/speed servo, you should be ok.
However, I always recommend a UBEC over 3s or 8 cells. The ESC will just heat up more because of the BEC and that's the last thing you need. Think of it this way, running 4s on the built-in BEC with a 1A load will force the ESC to dissipate over 9 watts. That's really a lot.
jollyjumper
RC-Monster jumper
02.11.2007, 12:34 PM
ok, thank brian.
i will be running servo's of the digital kind with 8kg of torque or even better.
so i'll need the bec then.
i tested a motor of my truck(stocker) and on 7.2volt it only did 15k rpm.
so i'll be runnig 4s lipo or or 12 cells NI-MH anyway.
then it will do about 40~45kph.
thats good for me.
losi 8ight-t
xray xt8
02.11.2007, 01:31 PM
Your ESC will thank you. ESC temps will be lower too and that's a good thing! :027:
jollyjumper
RC-Monster jumper
02.11.2007, 04:21 PM
well something's off.
maybe its the bec.
the steering suddenly lost lots of torque.
my servo was a little warm.
will try other servo tomorrow.
will see then. hope its not the MM.
losi 8ight-t
xray xt8
02.11.2007, 04:58 PM
maybe its the bec.
Sounds like the servo isn't getting the power it needs. The built-in BEC in most ESCs are linear ICs. They usually have some type of thermal and overload cut-off to pretect themselves. Measure the voltage on the BEC (use a servo Y adaptor) while working the servo and see what the voltage looks like. It could be driving the BEC into overload (from the hi-power servo) and cutting back the voltage.
jollyjumper
RC-Monster jumper
02.11.2007, 05:01 PM
could all this start all of the sudden?
losi 8ight-t
xray xt8
02.11.2007, 05:14 PM
I suppose it's possible. The internal BEC is supposed to have protection, but if it was pushed too far too often/long, it might be permanently damaged, which would explain the suddenness. Again, measure the voltage while the servo is moving and see what the voltage does.
jollyjumper
RC-Monster jumper
02.11.2007, 05:15 PM
will do, but dont have a y-wire here.:mad:1
losi 8ight-t
xray xt8
02.11.2007, 05:18 PM
Well, if you have an extra servo connector and wire, plug it into an unused receiver port and measure it there. The output voltage on the receiver will be the same on all ports...
