02.15.2007, 08:45 AM
Originally Posted by standard_63
How much difference do the fins make over the smooth can? Anyone know for sure? They are there for more than looks, right?
It is there dissapate extra heat from the motor, Imo, id take a wanderer with a RCM heatsink since there are no possibilities in loosing the front/rear endbells.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
02.15.2007, 10:24 AM
I'll second that, the fins are the heatsink and discipate heat from the motor. I love running heatsinks on my motors if at all possible.
02.15.2007, 10:33 AM
the fins will help more than a heat sink as a contact of heatsink is not perfect and using thermal paste is not really an option on this type of heatsing it also does not cover whole motor so fins are in my oppinion better but they limit pinion use bit more. well nothing's perfect :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
02.15.2007, 10:48 AM
I have to agree with that statement, BUT, i have already seen a couple of XL "C" motors front end pop off, now if they were screwed on, i would clearly say that they are a better buy, but they are epoxied so there is a chance they can come off over time. But now if you get a Wanderer XL with a heatsink, there isnt much to worry about!
Losi 8ight e
RC-Monster jumper
02.15.2007, 10:51 AM
so i take the wanderer is pressed together?
thanks.
02.15.2007, 11:42 AM
The wanderer has its front pressed with epoxy and the same goes for the rear endbell, but with a RCM heatsink it is protected both ways so there arent any chances of it coming apart.
Losi 8ight e
02.15.2007, 11:46 AM
Yes, the Wanderer's are pressed on.The RCM heatsink/motor clamp works very well to keep the end on and shed the heat though. Fitment is easier too since you can position the heatsink differently if the fins are in the way. And, if you need to mod the fins, you are only modding the sink, not the motor.
The fact that the C motors have integrated fins vs a motor with goop-coupled heatsink has little impact IMO. Whenever I have taken temp readings on my 10XL and the heatsink, they were very close to each other. Any differences were more due to the measuring inaccuracies (distance of temp guage, emissivity setting, etc) than inefficiencies of the bond. I'm sure there are differences, just nothing to really consider.
RC-Monster jumper
02.15.2007, 12:07 PM
ok, thanks for the info guys.
02.15.2007, 12:30 PM
I have had my 10xl wnaderer for some time now, it was my second BL motor(first was the hv). I have never had a problem with the end bells ever. I agree with Brian that discipation between the two heat sinks is very minimal.
02.15.2007, 12:53 PM
Originally Posted by neweuser
I have had my 10xl wnaderer for some time now, it was my second BL motor(first was the hv). I have never had a problem with the end bells ever...
I assume you are using the RCM heatsink with it?
The bearings on my 10XL needed to be cleaned recently, but other than that, I've had no problems with mine either, and I use the RCM heatsink.
IMO, what makes the C motors more attractive to buy is the fact that the C motor is cheaper than the equivalent Wanderer once you add the RCM heatsink.
02.15.2007, 12:57 PM
That is correct Brian. I use the RCM heatsink and the 10xl wanderer. I really like this motor too. It has been through a lot and is still like new. I only had to clean my bearings a few times, which is really easy to do. I also had a 9xl (wish I would have kept it) that ran really well. Same set up, RCM heatsink and all.
02.15.2007, 01:05 PM
Yeah. About the cheaper part, i would rather spend that extra 20 bucks and be sure its on there tight!
Losi 8ight e
02.15.2007, 01:09 PM
Exactly! Especially now that we know the endbells on the C motors aren't quite as solid as originally thought. And $20 is really a pittance compared to the amount of money we all spend cumulatively on these projects! :eek: And quite honestly, if someone is quibbling over $20, they are in the wrong hobby!
02.15.2007, 01:11 PM
My thoughts exactly!
Losi 8ight e
02.15.2007, 01:13 PM
I wish I could by that cheap all the time! Say like a BL motor for 20.00! LOL, I know, I know, wishful thinking!
