tallyram
tallyram's Avatar
02.16.2007, 06:23 PM
Originally Posted by Serum
i doubt if the 8 spiders are any stronger than the 6 spiders.
The 8spiders use aluminum gears, while the HB's use hardened steel gears.
I have seen several UE shafts broken...
all the hb's at my local track shred the gears in their diffs even though they're harden steel, they don't mesh correctly. i'll just do what the nitro guys do and put kyosho gears in.
  Send a message via AIM to tallyram
Serum
Serum's Avatar
02.16.2007, 06:31 PM
I don't know what kyosho gears? the kyosho gears i know with a 4mm hole are from aluminum.
Shimming is the key..
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.16.2007, 06:43 PM
i would think hotbodies diffs are stronger then kyosho ones.
indeed shimming is key to bullet proof diffs.
the kyosho 43/10 R&P sets are knowen to strip.
so i got the hotbodies coming my way.
losi 8ight-t
xray xt8
tallyram
tallyram's Avatar
02.17.2007, 12:06 AM
diff gears only. i will only change the diff gears inside the diff cup. r+p are ok. go to truggyracers.com and check the hb forum. i know you have been there serum, i saw your conversion.
