riverat1540
riverat1540's Avatar
04.17.2007, 08:36 PM
ok here is what i got. i have a 88tooth spur and a maxamps 8000mah 3s 11.1
volt lipo im running a 26 pinion and using stadium truck foam tires. and have had max speed of 53.5mph. is there anymore info needed?
oh i also found this if it helps
AznJunkie -> car gear ratio calculator (6/3/2003 10:19:19 AM)
Ratio for Evader:
Internal: (Transmission only)
2.66:1
Outer: Stock Spur gear (88t) / Pinion (20t)
4.4:1
To find out your final ratio. Take your spur divide by pinion then multiply by internal ratio. So:
Spur / Pinion = ? X 2.66 = Final ratio.
Sorry don�t know how to get Max RPM.
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
