AAngel
05.11.2007, 12:56 AM
I was about to slit my wrists. I wanted something better and more efficient so I ordered a Compro ($200+). That was defective, so it's on its way to the Czech Rep. Since I couldn't wait, I ordered a Quark. I got it yesterday. I was so excited that I wired it up and took it for a run. My first impression was, "man this is smooth." I ran it for a few minutes, then shut it down to go fix dinner for the kid. After dinner I came back out to run it, and what do you know...cogging. I knew it couldn't be the controller, so I removed the connectors and hardwired everything. It ran great for about two minutes, then more cogging. I desoldered and resoldered everything, still cogging. I call Quark and they say that there was a batch of controllers that had bad caps in them. I have to send it in. What are the odds that I could spend almost $600 on controllers and have nothing to run my 5S packs with? That's just my luck. Now I have two controller in the mail.
So...anyway, the caps came in today. They were waiting for me when I got home. I used some 1/8" copper round stock and put it in a vice and flattened it. I cut two strips and soldered four caps to the strips and then made a channel out of copper sheet and then embedded the cap bank in epoxy that I mixed with aluminum oxide powder. I didn't do anything fancy with the bank. I just cut away some of the insulation at the front of the power leads and soldered the cap bank in using some 12 gauge wire. Not pretty, but effective.
Some pics...
I took it out to the track to try to break it, so I ran for about 40 minutes. It was geared 11/44, which I don't think is undergeared, since I usually run 12/46 with the 8XL in a truck and 14/46 in a buggy.
After running and only giving the truck a break long enough to change battery packs, get this...motor temp 218...esc temp 110. The battery was so cool that I didn't even temp it.
I'm not willing to swear that the caps made that much of a difference, but I had some really cool running tonight. At this point, I may have to sell both the Compro and the Quark when they get back. I'm assuming that I'm going to get new units back. The Mamba Max was running way to good. When I say there was zero cogging, I mean exactly that. No cogging at all.
As far as "the more the merrier goes," it's looking like four is merry enough for the MM.
BTW, I did try the cap bank on the Quark, it didn't help. There's something really wrong with that thing.
I have the caps divided up and will ship them tomorrow. You guys should have them by Monday or Tuesday.
