neweuser
neweuser's Avatar
05.14.2007, 04:41 PM
Well, in the case with the MM, the CC motors are a higher kv rating, and most like to push the esc more than 3s or so, so a lower kv is preferred. The KV on the CC is just too high to be running 4s 5s lipo in some cases.
So, with that said, the MMM will MOST likely be a high, so to run a higher voltage system, a lower kv will be in order which is why most will get just the esc. Correct me if I'm wrong here guys.
