05.28.2007, 06:08 PM
The HvMaxx will run much hotter, have shorter ru times and rev like mad on 12cells- 60-70,000 I believe = not good. The 9xl will run cooler, run longer, have more torque which is good for a heavier truck setup, and you have the option of adding up to 16cells or more with the right esc. The HvMaxx by comparison will only take up to 14cells, doesnt have as much torque since its a shorter motor, and will struggle with a heavy truck setup (I should know). In a light truck though- sub 10lbs - then the HvMaxx is an option, I have seen videos of it in action and it is impressive. What does your truck weigh at the moment with the titans and 12cells on board?
