zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.02.2007, 04:38 PM
Yes, when you set the cut-off voltage, you do that first, then go into programing again and select Li-Po 'normal' or 'high'.
Also, you should use at least 2.8v cut-off for lipo's minimum. I have A123's, I use 2.2 volts cut-off, A123's dump very quickly, hold there voltage right up to the last few seconds.
