padailey
06.25.2007, 06:15 PM
There is quite a bit on www.rctech.net about the platinum lipos (orion 4800's). You are correct AAngel that they don't say you need to balance them....
From Orion website• What is cell balancing and does the Team Orion Li-Po require it?
Cell balancing is a way of ensuring your Li-Po will deliver the maximum performance and capacity over a prolonged period of time.
With Kokam’s unique battery design, balancing is not absolutely required
but they also say if you want to be sure you can charge each cell individually which will balance the pack. Find it on RCtech on how to hook up the charger leads... its something like + to +, - to balancing plug charges one cell and + to balancing plug, - to - charges the other. You would also do the same thing to check the voltage of each cell. Here is how they recommend rewiring the Orion Avionics balancer for the Platinums...http://press.teamorion.com/press/cli...ncingInstr.jpg. Should be similar for the LBA10.
