MetalMan
MetalMan's Avatar
09.27.2007, 01:51 PM
When I installed it onto my "sparkling new" laptop, I had to right-click on the downloaded setup file, and choose "Properties." Then select the tab labelled "Compatibility," then check the box at the bottom next to "Run this program as an administrator." Click "OK," then run the setup file again (should be V3.01, BTW). Once it's installed it should work just fine :).
