10.01.2007, 11:13 PM
p.s. if the tranny is in the normal e-maxx way and you left the diffs alone your esc is probably running backwards, standard mm programming allows reverse to stop to forward transitions, but when going forward you have to stop, wait three seconds, then you get reverse so, can you go reverse to forward? or do you have to wait three seconds after reverse to go forward, cause then you are backwards, and if you can go straight from forward to reverse you are backwards
