10.12.2007, 09:56 AM
I was thinking more along the lines of a slipperential type tranny. Use a top shaft with a slipper and 18 tooth gear, put a k type ofna diff with the 51 tooth plastic spur. Then used modded mgt or jato spurs on the slipper and compatible pinion. 2 custom bulks would have to be made, as well as upper and lower mounts. Upper mount would have to tie into the shock tower. This setup would retain a slipper and give gearing choices. Also the use of the 51 tooth diff gear would allow some room for outdrive clearance. I will mock something up and see if it is doable.
