Pinion/ring gear lub, what did you use??
david lamontagn
Pinion/ring gear lub, what did you use?? - 10.26.2007, 10:14 PM
The title speak for itself, i want to know which type of grease you use to lub you pinion/ring gear, in you diff case.
Not want to know which silicone fluid grade in your diff cup, but the grease using for the pinion/ring lubrication.
Thank you!
