10.31.2007, 10:40 PM
If you can open the case & possess a good iron, it is simple enough to replace the caps with suitable ones yourself; but only if you are confident- dont think about it if you are even the slightest unsure. Castle will fix that for the standard fee I would have thought- $25 isnt it?
GriffinRU could perform his stage 1mod on it for about $50 or so... (better caps of the same voltage rating to improve cooling and reduce voltage sagging under load).
