Matthew_Armeni
Matthew_Armeni's Avatar
11.17.2007, 05:03 PM
What I would like to see, as a basher part time club racer-
(Some of these may be a given but I didn't want to leave any out)
-Programable. The pit wizard was awesome, and it'd be cool to bring it back but being able to hook up to a computer instead of counting blinks of LED's is really great. This is something I really like about my mm.
-Plugs on both sides of the sensor wire- excellent idea suicideneil
-How about bullet plugs for all the wires that go into the ESC? I could make different length motor or battery wires for different cars without having to near my expensive ESC with a hot soldering iron.
-Please no Tamiya connectors, those things need to go away!
-For easier plug and play a built in HVBEC would be awesome, I know the current HV system works without a seperate BEC but only if you're running 2 seperate packs plugged into your seperate connectors, if you're running 1 4S pack you need a seperate BEC, I personally do not like running 2 packs.
-and on the subject of 2 packs, while I don't like it a lot of people do, so 2 connectors like the current HV and a shorting plug with the controller for people like me
-lipo cutoff built-in
-full function fwd/brk/rev/brk only, double pump is the best
-no less than 4S capable(which your current setup has so I'm not worried about that) and some people will want more but at what cost? Is increasing voltage capability something that can be done without a lot of programming? I don't know these things but if so multiple models could be offered, sport, pro, etc. allowing power mongers to get the power they want and new guys (or poor, if you're like me) to go with a less expensive setup
-more than just 2 motor choices, pro and sport models (again, cost)
-and with the motors, how about a flat spot for the pinion screw from the factory? That'd be nice.
Well, that's all I can think of right now, but my big one is it being programable. You guys make awesome products and I'm sure it will turn out well, and opening it up for ideas and comments shows how much you guys listen and care about the consumers, good job.
  Send a message via AIM to Matthew_Armeni
