Finnster
KillaHurtz
Finnster's Avatar
12.10.2007, 11:43 AM
If you set the cutoff higher, then the motor will cutout even sooner. You can set it to lower # of cells, but at that point why bother? Running a 3S lipo down to ~6v (2S setting) is bad.
As said, race mode disables all safeties. No LVC, no motor power reductions, nothing. Its the "its in your hands, be careful not to break it" setting.
You want some sort of safeties, if the LVC @ 3S cuts out on you to early, you may need better batteries to a more flexible external LVC.
