Serum
Serum's Avatar
12.10.2007, 12:39 PM
Check to see if there is no stuff in the bearing holes. use a toothpick to poke them out.
Are you using the 43/13 or the 43/10 diffs? if everything is tight in place, it's pretty hard to solve the problem. It either takes a deeper bearing hole behind the ringgear or behind the pinion.
The 43/13 diffs do fit in my diffs.
With no pinion in place; have you got any room on the diff inside the case? (4 screws tight in the diff, 3 screws tight in the bulks) try to see if you can move the diff left/right
