IBJAMMIN
IBJAMMIN's Avatar
12.21.2007, 04:59 PM
Very interesting a clutch could also help eliminate cogging by reducing the load at start on the motor?
Q does the adapter have a STD 2 pin configuation so you can try different style clutches?
I would be very interested in trying this out in my CRT with the 1515 Neu and MM esc to see if it will eliminate the cogging issue?
I was looking at your pic and how you used a bell crank to work the brakes and it seemed a little complicated you can eliminate it by redrilling the holes on the brake cam and moving the brake arms you can push 1 side and pull the other see pic. :)
