ssspconcepts
ssspconcepts's Avatar
01.04.2008, 10:40 PM
You all talk about cogging w/the mm esc a lot. For now I just installed it in my mbx-5 w/ a Feigao 9xl . First, exactly what is it and how can i prevent it or correct the prob. when it happens.
You should be okay with the MM and Feigao 9xl combo...I didn't see any cogging when I tried that setup. But if you do see cogging (sort of like stuttering at take off), you can use a smaller pinion and/or adjust the time on your MM controller. Don't forget to also keep an eye on your temps...changing the pinion size will influence your temps...follow the guidance in BatFish's thread:
http://www.rc-monster.com/forum/showthread.php?t=2200
Hope this helps.
